Removing TB: anything I should be aware of?
Old 09-10-2008, 04:08 PM
xchevyx24's Avatar
Originally Posted by 00ChevyScott
or put it in neutral...
what a dumbass
or turn off you engine
Old 09-10-2008, 04:39 PM
Denali Dude's Avatar
I dont want to Start a New thread I just wanted to know Where can I get a ported TB I dont want to port mine I want a new ported one And what are the gains will the throttle response get better?
Old 09-10-2008, 04:42 PM
JakeBrakeIH's Avatar
Is the throttle body freezing up REALLY that big of an issue up north?
YES it is...it get freakin cold up here bub...
Old 09-10-2008, 05:10 PM
Wearin' da big hat
00ChevyScott's Avatar
It feels like this in texas >>>
Old 09-10-2008, 05:26 PM
GMCtrk's Avatar
I was in the same boat. I bought mine off a member here and sent it to a porter that I learned about on LS1tech. It was $55. It just came in today.
Old 09-10-2008, 05:31 PM
Wearin' da big hat
Why didn't they work the air passage in the top left part? Mine was filled with JB weld and had the tunnels drilled and brass tubes inserted into it.
Old 09-10-2008, 06:41 PM
GMCtrk's Avatar
That's known as "expoxying" and they don't do it because it can end up blowing into your intake and it shows no gains either.
Old 09-10-2008, 06:43 PM
GMCtrk's Avatar
Also, massive FAIL on the TB swap. I had to go to NAPA to buy a 10mm socket so I just did the work out in their parking lot. Got the whole TB off and I couldn't figure out how to take off that little black thing holding the 2nd cable WTF? How does that black thing come off? Also, what is that second wire even for? Cruise control? BTW, I'm referring to the black piece that hooks onto that little **** on the left hand side of where the throttle cable goes.
Old 09-10-2008, 08:52 PM
Wearin' da big hat
ya thats the cruise control cable, and its a bitch to get off.
Mine actually isnt even hooked back up because evidently there is a difference in that ***** size between years of throttle bodies, because my plastic hole was too small to fit over the larger **** on my p&p'd one.
Old 09-10-2008, 09:20 PM
GMCtrk's Avatar
how do I get it off? My replacement TB is the same year as my original (2000)
Quick Reply: Removing TB: anything I should be aware of?
