Results from installing AFR 205 heads
75rwhp - no way. Youshould make good gains with a good sized cam and heads that really compliment the blower. But heads alone probably are worth 30-50 depending on what you get and what you had.
Originally Posted by DanaliHD
it was suggested to me that I should put Lingenfelter stage II heads on my truck. Anyone have any thoughts on that? dude claimed it should easily give me 75rwhp.
If I had to do it over again, I'd throw an STS turbo on there!
You need more cam for thoses heads,220-560-114LC,get more injector, and like TeX said newer PCM and a local dyno tune,look around the vette forums and look for local chaperts find out the vette guru tuners and call and find out if they specialize in trucks also,im sure theres plenty of supertuners in Cali
100K miles on a 6.0 shortblock? thats nothing if its been maintained,im sure it has.
Originally Posted by 99 2500
I tried the Wester's tune before the cam swap and it made the truck slower and burn more gas, was very dissapointed that it could not perform better than the Hypertech.
Originally Posted by BigTex
Good info. I can guarantee you that you'll feel a huge difference with a good tune. Do a search here for guys swapping out the 99 PCM for 01 or 02 year models. The tune for those years is much better. Everyone who has done it on a 99 model agree - better throttle response, better mileage, more power. Get a custom tune based on one of these year model tunes and it will be even better.
The biggest problem with getting a tune is that I live in Belize, Central America and the closest drive to get tuned would be to drive to Houston. Gonzo 6.0 is right about the short block being in good shape, I could still see the cross hatch in the piston bores, I was surprised.
I bought the AFR190s for my car about 2 years ago. Really nice out of the box heads. Could tell a pretty good difference. The only problem I had with them,I put a little to much umph on the A/C bracket bolt. Stripped it and had to stick a helie coil in it.
So living down there you can kick *** on 99% of all the trucks there,just the way you it is now.Either tune it yourself like Flyer said or do a Nelson,anything but hypertech,your leaving to much on the table,buy a wide band so you know where you are at now.
