Retune with stall converter?
Well, in my case, I had to retune because my downshifts were way off. But of course, I added the transgo and vette servo and had all my torque management removed all at the same time, so that may have had something to do with it.
But before my downshifts were corrected, if I floored it, there was about a 2-3 second delay before the truck would downshift and **** and get.
Yeah, I couldn't really figure that one out. I don't know alot about tuning but I wouldn't think that a different converter would change things that much. My buddy got his cam and tune from Texas Speed and his car is quicker than ****.
SierraCrew, that was due to the shift kit. The shift kit change some things in the valve body that makes it more responsive. It also does away with the PWM TCC lockup, which is when it feels like the converter is kinda locked. That's probably what you were feeling is the lack of the PWM TCC lockup.
In that case, the trans shift tables and TCC apply prolly should be modified, but not necesarily because of the converter.
Yeah, I kinda figured that it was due more to the shift kit than anything. I was pretty sure before the install that the torque converter didn't really require any tuning, but I am not an expert on this either so I wasn't really sure.
Originally Posted by KLUG'S SS
I was just wondering how important it is to get PCM retuned after putting in a stall converter because I am getting a nelson tune very soon but I don't plan on doing the converter for a little while yet. Anybody have any input on this?
To harssh of a 1-2 shift is very bad on trans parts. It will cause them to bang, banging parts will break. That's not exactly what you want when you do your shift kit.
FormerVendor
sometimes the 1-2 is just right mostly under heavy throttle but, at lower RPM's it seem to hit to hard when shifting around 2000-2500 and when colder I dont know how to solve this problem as its spuradick anyone else experiencing this
Originally Posted by Naked AV
Most if not all vehicles benefit from a tune. Factory tunes are conservative, which means they burn a little rich (to be safe and avoid detonation) but this also means that there is always some power left on the table that can be recovered by getting a tune. Most tuners do transmission tuning and remove some or all of the torque management that robs power, and the can change your shift points to higher RPM's. There is a lot that can be done to a stock vehicle. Some people would even say that your first mod should be a tune. With Allen it is a good deal because if you get his tune on your stock vehicle and then make changes later, the updates are free.
I stand corrected, and thank moregrip for setting me straight on this.
Actually ... it pulls timing to keep the warranty claims down on the shoddy 4l60e. They can't build it to hold full power shifts and still be silky smooth like it is from the factory. That's the whole idea of torquw managment anyways. It will pull as much as 50* of timing!
The 14.7 is stoich, but when the PCM goes into PE mode, which is where it considers WOT (definable in the tune) it goes to a much richer mixture.
FYI, stock, these trucks go into PE mode at 90% throttle, but the RADIX tune puts it into PE mode at 40% throttle which is when it starts seeing boost, about 2-3 psi is what they aim for I think.
LCHEE
10-24-2020 04:10 PM
LSX-81-SIERRA
08-31-2015 05:52 PM
