return style fuel to return-less
Old 01-07-2010, 12:59 AM
TXsilverado's Avatar
wouldnt the corvette fuel filter with a built in FPR be considered an external FPR?
Originally Posted by truckmann
I have the corvette filter on mine plumed to the TBSS fuel rail. It was the easiest way for me to put on the TBSS intake. The fuel system seems to be working fine. Still having problems with the TB, but that's another story.
any pictures of how you did this?
Old 01-07-2010, 01:02 AM
The LS1 powered Camaro's were return systems, returnless started being used in 04'
then why did i have to use a fuel rail from a 97 or 98 corvette only....im wanting to move to the camaro fuel rail now.
Old 01-07-2010, 08:44 AM
truckmann's Avatar
I used some nylon braided AN line and connectors to hook it up which was pricey but if cost is an issue you could just as easily use rubber fuel injection line and fuel injection clamps.
Here is a picture. May not be the best way to do it but it doesn't look bad and works fine. If I had an engine cover that fit on the TBSS intake it wouldn't even be seen.
Old 05-25-2010, 11:26 AM
Cook's Avatar
any updates on this guys? I need to do it, I heard I can swap a corvette fuel filter in it and be fine but im not sure.
got part numbers?
Old 06-03-2010, 09:30 PM
chevysten's Avatar
I used the Vette filter/reg on my swap and works great,BUT right now at wot fuel pressure dopped from 58-35.It has the Walbro 255 intank fuel pump too! I bought a HOTWIRE kit,basically a larger gauge wire from the fuel connecter to the alternater and it only drops 10 psi.Hopefully I can get it tuned without any issues now!Dont know what else it could be.We'll see tomorrow. Mike
Sevex
08-22-2015 12:12 AM
TAPyvehc93
08-08-2015 06:35 PM
GMCtrk
07-17-2015 06:39 PM
Deceptarado
07-08-2015 05:24 PM
Quick Reply: return style fuel to return-less
