Rev Limiter ?
Old 10-15-2005 | 10:32 AM
Bradazz's Avatar
Default Rev Limiter ?
Every now and then I hit my Rev Limiter on the 1-2 shift and sometimes the 2-3 shift only when I floor my truck, I had Jesse set my shift points at 5800 rpm with the rev limiter at 6200 rpm. With the Tow/Haul button my truck shifts @ 6000 rpm with the rev limiter at 6200 rpm. The problem seemed to start after I had my 3000 Stall Converter & 4.10 Gears installed which I had Jesse retune for those changes. I am thinking that I just need to set my rev limiter higher but I do not know what it should be set it at or if there is another problem I am overlooking.
Blwn99x
03-24-2023 12:14 PM
Infernohoe
48
10-02-2015 11:25 PM
nic351
09-24-2015 10:43 AM
fortune46x
09-16-2015 09:18 AM
TAPyvehc93
09-14-2015 02:22 PM
