Rev limiter???
Old 12-06-2010 | 07:53 PM
miller white's Avatar
Default Rev limiter???
My truck is stock, besides msd wires and an intake. And for some reason I can punch it from a 30 roll and it downshifts. But it hits the rev shifting to 2nd??? The trans isnt slipping or anything? Any insight would be awesome, thanks guys.
Old 12-08-2010 | 11:07 AM
Dalton's Avatar
sounds like the tune could use some revising
Old 12-08-2010 | 01:50 PM
baSICK5.0's Avatar
+1
Mine was tuned for the Rev Limiter at 6,200-6,300. I never manual shift, Always drive in D. It shifts at 5,900 on its own...only way it'll hit the limiter is if it somehow sees neutral or some **** breaks.
Old 12-08-2010 | 02:05 PM
viciousknid's Avatar
Where's the Beef?
It's possible he increased the shift points without increasing the rev limiter. It's also possible that the clutches are starting to slip at WOT.
Old 12-08-2010 | 03:31 PM
Atomic's Avatar
I have a gauge for that
bingo
Old 12-08-2010 | 04:22 PM
meangreenburban's Avatar
my old truck did it when it was cold out on WOT 1-2 and 2-3 shifts. It wasn't a problem in summer, but in winter it would bounce the limiter on a WOT shift.
Old 12-08-2010 | 05:45 PM
fredkj3's Avatar
mine used to do it on my 01 every now and then when i had the shift point at 6k and rev limit at 6200..... they could be too close...
i moved shifts to 6300 and rev to 6800 and never had any other issues till the output shaft broke.....
Old 12-08-2010 | 06:40 PM
Where's the Beef?
very true. I have mine commanded to shift at 6400 but it sometimes won't shift until 6500-6600
Old 12-08-2010 | 10:59 PM
The tune is stock I've never had it messed with before?????
Old 12-09-2010 | 01:48 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Either a tuning issue or your band is on the way out. If you're downshifting at WOT on a stock transmission, it's really just a matter of time.
Start saving up for a built transmission.
