Rod Bolts ???
Destroyer of Transmissions
Check with ARP to make sure you don't have to do any tapping or boring for those to fit your rods. Also, find out if you are or are not supposed to tap out the shims in your stock rod bolt holes. I ordered mine from Kaetech. Tapped the shims out, lubed the bolts and torqued them to 50 lb/ft, done.
Truck addict
i have read where the kaetech's are easier to use do to them not having to be honed or anything. i am still in the research phase myself as for i will be changing mine out very soon as well.
Yohns Kustom Fab
08-25-2015 06:53 AM
