Roller rocker question???
Old 04-08-2009, 12:23 AM
  #21
jophuss36's Avatar
id like to see a dyno chart of the HP/TQ curve.
I had the truck dynoed once after the cam install and wasn't able to get a tune because the stock injectors became usless I think it dynoed at 318 305 but after I put some 43lb injectors and had it tuned we were guessing about 340 345 horse it will spin the 33s from about 15mph the 31s will spin from 35mph!
Old 04-08-2009, 05:50 PM
  #22
ForcedTQ's Avatar
Originally Posted by jophuss36
I appreciate it I actually bought new harland sharp rockers and was getting ready to install them Thursday along with my heads and was talking to thunder racing (shayne) he told me that they would be worse than the stockers on my setup, he said any roller rocker on ls motor is bad idea, especially with the ramp rate and agressiveness of the lobes on my cam. Imwondering if I should send them back
Give me a break, he really told you that? So the concept of decreased side loading of the valve tip (and consequently decreased valve guide wear), rather than drag a fixed nose rocker across the valve tip during quick ramp rates that increase side loading, is a bad idea???? Does anyone else see my point here?
Old 04-08-2009, 07:46 PM
  #23
jophuss36's Avatar
I might habe missunderstood his theory myself but im not an engine genious, but after doing slot of research I have found the harland sharps are a bad idea, I do believe that I want a roller rocker but think I'm going with a shaft mount possibly yt's. There's no way types would cause problems.
Old 04-08-2009, 07:49 PM
  #24
nonnieselman's Avatar
Just leave the stockers in there and be done. Thats what id do anyway.
Old 04-08-2009, 11:17 PM
  #25
jophuss36's Avatar
the only thing is that trickflow will only warrenty the heads if rollar rockers are used
Old 04-09-2009, 12:38 AM
  #26
ForcedTQ's Avatar
Lightbulb
Possibly citing the very thing I listed in my post above about valve side loading? Or could be due to rocker arm mounting pads designed for use with roller rockers? Rocker stud mount diameter? Possibly a myriad of concerns. I re-read through your thread and do agree with the others about the stock rockers being lighter at the nose and pushrod cups (This is where it counts as extra inertia at these points will just lead to reduced valve-train stability and lost power). As long as the bearings on the stockers are in good shape and the contact points look good they should be usable.
Old 04-09-2009, 11:36 PM
  #27
jophuss36's Avatar
has anyone ran roller rockers for over 20000 miles without any problems
Old 04-10-2009, 02:45 PM
  #28
PT's Slowest Truck
budhayes3's Avatar
I've got about 15k on mine without any problems...
Old 04-10-2009, 03:45 PM
  #29
Where's the Beef?
viciousknid's Avatar
So buy new STOCK rockers.
Edit:
I think the real question is. Has anyone ran a huge cam in high rpms for that many miles. As you were told, they aren't good for a cam Your Size and Ramp Rate. So comparing it to a smaller cam wouldn't really help any.
ss454327
10-17-2015 03:43 PM
spiritfish
08-24-2015 05:04 PM
BigEd_72455
08-08-2015 07:37 PM
USMCvet0311
08-01-2015 07:45 AM
supersportsteve
07-04-2015 12:02 PM
Quick Reply: Roller rocker question???
