Roller Rockers?
Originally Posted by slamedboosted&shaved
I have a whippled 5.3L, i'm about to put a zo6 cam ls6 spring and hardened pushrods. which if any roller rockers should i get and what ratio?
Jesel, Yella Terra and Granatelli make a very nice non adjustable shaft mount rocker. Those are the best in my eyes and why I run Jesels and will run nothing else.
Originally Posted by BBT
The stock rockers are pretty good and will be a little quieter than the roller tipped ones. I have the Yella Terra's 1.7 that I just removed from my 2001 LS1 motor after 14K miles because I wanted to quiet down the valve train just a little by putting the stock rockers back on (I have the comp 918 springs which also contribute to valvetrain noise). You should stick with the stock 1.7 ratio which will give you .550" lift with the z06 cam. I would also consider a better valve spring (like the Crane duals) to help close the intake valve against the boost pressure you'll be running....
Originally Posted by 99Silver6.0
My valvetrain is quieter than it was stock!!!!!!!!!!!!!!!
KINGCYCLES
10-02-2015 11:21 AM
