roller rockers
It's two totally different benefits. The roller rocker Uses a needle bearing in the fulcruum(?) to reduce friction allowing the movement of the up/down motion to be easier with less heat. The Longer ratio Opens the valve a little further allowing more air flow, Kind of like having a little bigger cam.
Originally Posted by 99Silver6.0
More lift and some duration. Thats it. Easy way out instead of changing cams.
Advice: Do NOT get an adjustable rocker.
Originally Posted by QuietTahoe
Why wouldn't you want an adjustable rocker? An adjustable rocker can accommodate any stackups in other valve train imperfections. Maybe I'm not to bright, please educate me. I have the Crane "Quick-lift" 1.8's on my truck and they are fantastic. Easy to install (if your reading comprehension skills are adequate), lots of power and throttle response, and quieter than stock. What am I missing here?
