Rollermaster timing chain problem ?????
I am installing a roller master timing chain. the problem is the new crank gear pulley in the kit slides on by hand all the way and usually you have to tap them into place the last little bit. Is the the way these are made or did i get a bad crank gear.
according to the box it is a 1140, which is the one i assume is for the SS's. It lines up properly, and looks totally fine. It just doesn't press on to the crank. I have it totally installed already and just tightened that crap out of the balancer bolt, so it shouldn't go anywhere. I guess i will see how it runs
I've not installed it yet..
