Rough idle after going from 19#'s to 24#'s
If it were me, I'd listen for a suicking noise from them first to see if its obvious. If its too loud, then I'd shoot a little spray carb cleaner at each of the injector ports. If there is a leak, it should rev up when the carb cleaner is sucked in. Also take a look at any other possible sources of intake leaks you could have caused.... throttle body, EGR, PCV hose, etc...
IMO the easiest way to determine what's wrong is, hook your truck up to a GOOD scan tool, like Tech II or a Auto X-Ray with Data scan features. Then you could monitor your injector duty cycle and see what's happening when it falls out.
