Rough idle after going from 19#'s to 24#'s
Old 05-22-2007, 10:32 AM
BigTex's Avatar
If it were me, I'd listen for a suicking noise from them first to see if its obvious. If its too loud, then I'd shoot a little spray carb cleaner at each of the injector ports. If there is a leak, it should rev up when the carb cleaner is sucked in. Also take a look at any other possible sources of intake leaks you could have caused.... throttle body, EGR, PCV hose, etc...
Old 05-22-2007, 10:33 AM
IMO the easiest way to determine what's wrong is, hook your truck up to a GOOD scan tool, like Tech II or a Auto X-Ray with Data scan features. Then you could monitor your injector duty cycle and see what's happening when it falls out.
Old 05-22-2007, 11:04 AM
RandomHero's Avatar
well I know when I retuned my truck for my 8.1L injectors it wouldn't idle for **** either. Just let your truck idle for a little while in park and drive and it will smooth out. I know mine did.
Pimpinpete
43
12-22-2017 08:13 AM
bearden86
26
11-15-2015 03:58 PM
BlownHD
10-03-2015 12:24 PM
02AWDAWSDenali
10-01-2015 05:08 PM
Pimpinpete
09-08-2015 07:39 PM
Quick Reply: Rough idle after going from 19#'s to 24#'s
