Royal Purple!!!
Originally Posted by *WILDSTYLE 5.3*
Well im going to switch oils and iv seen alot of threads about this stuff so i want to try it out. now my question is i have always used the lucas oil stabilazer should i or even need to use it w/ the royal purple??? thanks in advance guys!!
Originally Posted by SmokedSierra01
If you have been using conventional oil w/ stabilizer, do not bother going to RP or any other Synthetic. Once you run regular oil through your motor you will not receive the same benefits from the synthetic oil.
100% wrong
2nd fastest 5.3 ECSB
Yea I am talking about the stabilizer might cause the issue.. I have only heard bad things about it...just word of some mechanics. But also if you run a synthetic after you have been running a conventional oil for awhile, it will actually clean out the motor and if you have any leaks you will start to see them. Sorry I will try and be a little more clear next time.
Originally Posted by 2redgmc
BTW the site is an Amsoil sponsored site.
http://www.bobistheoilguy.com/gearoiltest.htm
There is a comparison of a Schaeffer gear oil to an Amsoil gear oil and the Schaeffer oil won. Can't imagine why that would be posted if Amsoil had such a heavy influence on the site...
Originally Posted by tb8100
I find that hard to believe after reading this article:
Schaeffer's is a sponsor and the independent Amsoil dealers are cash contribution sponsors.
The site has been after RP to sponsor the site sence 2002 when it came on line.
I could have told youthat Schaeffer's oil was going to out perform the Amsoil product.
Schaeffer's makes some good oil. Amsoil to but IMO the Schaeffer's is better than Amsoil.
2redgmc - It appears you work for Royal Purple. If so can you clarify again what the recommended oil/filter change intervals are for a daily driven vehicle? I know it has been covered on here just want to hear it from the horse's mouth.
