Running Lean All of a Sudden...Advice?
Old 08-27-2013 | 04:31 PM
trxmxzx's Avatar
13 Second Truck Club
i have had my MAF fail. same thing 19 afr... tried cleaning it, didnt do anything, got my hands on another one from a buddys truck worked like a champ. went and replaced one from auto zone 95 bucks later that was back in 08.
good luck keep us posted im curious
Old 08-27-2013 | 08:12 PM
GreenMtnSS's Avatar
Thanks fellas, looks like I am gonna do O2's and a MAF sensor and see what that does...
Old 08-29-2013 | 01:08 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Did you check the Intake Gaskets??? Even with only 10,000 miles, If you have the early style orange one's replace them with the new revised green ones that are ethanol compatible.
The orange ones don't like the ethanol in gas.
Also if the o-ring material is almost flat there is a good chance they're not making a good seal. As the engine heats up and things begin to expand and contract, if the seal is not pliable enough you will get a leak. Usually on the bottom side of the intake were its impossible to diagnose.
After that I would do the 02 Sensors.
MAF sensors are rare and you usually get a code indicating there not functioning properly.
Have used any type of Fuel injection cleaner??? It's possible for the injectors to gum up from sitting as well. it probably won't fix the lean issue but it's good maintenance on a vehicle that sits for periods of time.
Old 02-16-2014 | 09:28 PM
blownescalade62's Avatar
Did you ever find the problem to this? I'm having same issue on my truck and its driving me nuts.
stealthperf
34
02-14-2016 12:35 PM
05GMC4.8
08-07-2015 10:55 PM
Dirtywhite
08-05-2015 05:10 PM
signguy62
07-16-2015 06:43 PM
