Running NGK TR6s everyday
Old 03-24-2005, 12:58 PM
slowprocess's Avatar
Default Running NGK TR6s everyday
Nitrous guys...are you running these plugs everyday? I've heard to make the swap from the TR55s, but will this effect everyday driving/idling/motor passes? Tell me your experiences.
Old 03-24-2005, 02:37 PM
Weedo's Avatar
I'm not a Nitrous gut but I ran them in both of my modded Lightnings and am running them in my Turbo 6.0. Not sure if this helps...
Old 03-24-2005, 02:40 PM
BigTex's Avatar
I've run TR6s for the past 13K miles. You won't have any problems, and probably won't even know the difference.
Old 03-24-2005, 03:07 PM
Deckhand's Avatar
ditto
Old 03-24-2005, 03:48 PM
BigBlockChev572's Avatar
Most people when they swap out to TR6s say they have a really bad idle, that's usually because they've messed up their wires during the swap.
Philip S.
Old 03-24-2005, 04:17 PM
Flyer's Avatar
It will cause a little more misfire at idle, but with a cam, you prolly won't notice it.
Old 03-24-2005, 07:16 PM
N20GMC's Avatar
If had mine in my truck for over 20K and its just fine. It even ran faster with TR6's than it did with stock plugs.
Old 03-24-2005, 10:15 PM
Good deal! I really appreciate the replies, guys. TR6s it is when I do my next tune up(which will most likely be before the kit is installed).
Old 03-24-2005, 10:19 PM
ACDenali's Avatar
My truck has 62k on it. Would a change of the stock plugs be a good idea? What should I change them to?
Old 03-24-2005, 10:47 PM
I've run TR-6 plugs for the last year and never fouled a single plug.They even outlasted my plug wires.
Quick Reply: Running NGK TR6s everyday
