Running NGK TR6s everyday
Old 03-24-2005, 10:51 PM
slowec's Avatar
guess I should add tr6 to my sig , almost forgot they were in there.They work fine in my 04.No idling or other probs.
Old 03-24-2005, 10:56 PM
single digit dreamer
parish8's Avatar
for me tr6 plugs did have a noticably worse idle but still not too bad. no problems here running them everyday. now switch to tr7's and look out, tr7's run like **** at idle.
Old 03-25-2005, 01:07 AM
Originally Posted by ACDenali
My truck has 62k on it. Would a change of the stock plugs be a good idea? What should I change them to?
no not at all. the stock plugs will be fine well over 100,000 miles, but you could pull 1 to check it out. in my opinion if you were to change the plugs use the same as stock.
Old 03-25-2005, 06:01 AM
Formerly one92rs
one03sierra's Avatar
Talking
hey slow i did a lot of research on plugs and even burned a few up on the nos. i ended up going to a tr6 iridium plug due to the tip being very hard. they idled and ran great. the nos will not burn the tip off of an iridium plug either.
Old 03-25-2005, 06:17 AM
slowec's Avatar
Default Yes
Thanks, I can always use some good advice.
Old 03-25-2005, 07:56 AM
Truck addict
goshawk23's Avatar
Lance how much were you paying for the iridiums? i am in the same boat as slow and will be going with tr-6's but if the cost for iridiums isn't that great i'll get those vice the reg 6's.
Old 03-25-2005, 08:05 AM
12sec.5.3's Avatar
What are ya'll setting the gap at?
Old 03-25-2005, 08:13 AM
GMC SKI's Avatar
.32-35 Gap is fine and has made close to 600rwhp for me On my turbo truck
Old 03-25-2005, 09:08 AM
F8L Z71's Avatar
TR6 at .035 gap for more miles than I can count here. On the T/A and the Z71.
Old 03-25-2005, 09:23 AM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
TR6 at .35 daily driven with boost. No misfire troubles until I put in the big cam
Quick Reply: Running NGK TR6s everyday
