?'s on ls1 fans
Originally Posted by bluecajun5.3
what's the diameter of your single fan, i thought about doing that b/f i thought about getting ls1 fans.
I think it leaves about 2 - 3 " open on both sides of the radiator, and top to bottom it fits right in.
You don't have to spend a hundred bucks on wiring and pcm tuning to make them work. Just get a fan harness at an auto parts store for about 30 bucks and wire them to always come on when the key is turned forward. Try to get the fans with the plugs still attached, or you can get some at a dealer for 10 bucks. I have had mine wired this way for 2 years and the fans still work great.
When I ordered my Nelson harness I told him I wanted a switch so he sent an extra wire to tap into the wire going into pin 42. Basically you tap into that wire, run it to a switch, then run another wire to a ground. Whenever the switch grounds the wire going into pin 42 it will kick the fans on. Also the Nelson harness was $89 + $10 for shipping + $7.01 tax if you live in TX. Total on mine came to $106.01. It is worth every penny IMO.
