Sc and 112 lobe??
Old 02-07-2004 | 10:30 AM
getsome's Avatar
Default Sc and 112 lobe??
I am looking at putting a whipple sc on my truck. My mods are in my sig but the cam has a 112 lobe sep on it. I was wondering how much that will hurt me that it isn't at least a 114 or larger. Will it be worth putting on without a cam change because i don't want to change the cam? Any info will help and i know i will have to put stock pully back on. Just wondering what it will do.
Old 02-07-2004 | 10:40 AM
Flyer's Avatar
You will be levaing a lot of power behind from the boost bleedoff. I would look at geting a 114.
Old 02-07-2004 | 10:41 AM
Deckhand's Avatar
getsome, have you installed that cam yet? Im am considering a cam as well, and that cam seems like a good all around cam.
If so how does it feel/sound/etc?
thanks
Old 02-07-2004 | 10:46 AM
getsome's Avatar
It feels pretty good. I put a tt3000 and a nelson tune in at the same time. WoW is all i can say. A big difference between a stock 99 and that. It has a noticible idle but pulls pretty hard. Going to get it dynoed today.
Old 02-07-2004 | 10:51 AM
Flyer's Avatar
If your gonna run a blower, you should run a split cam too. With more exhaust duration than intake duration, you will get a lot more out of that blower.
Old 02-07-2004 | 10:55 AM
getsome's Avatar
Ya i was looking at compcams 216/220 525/532 114 lobe. Didn't know how much i woould gain with it and blower if it was worth doing or not.
Old 02-07-2004 | 10:56 AM
Deckhand's Avatar
cool, what do you think that cam will do without a converter?
I may get 4.10s here soon as well?
thanks bud
Old 02-07-2004 | 10:59 AM
getsome's Avatar
It would work good with a stock converter. It has power from like 1000 to somewhere in the 5800 rpm range by the way it feels. It is a reall good cam for a N/A motor. I have the stock 3.73 and it works good with them but 4.10's you can't go wrong.
Old 02-07-2004 | 12:09 PM
MNC5's Avatar
What your really looking for is less overlap which is affected by the Lobe Sep. A 114 can be worse that a 112 depending on the timing of the valve openings.
Tydriver
45
10-23-2015 09:19 PM
Jake75
10-02-2015 02:28 PM
chopperloco
09-28-2015 08:40 AM
bluebommer07
09-20-2015 08:42 PM
Jake75
09-08-2015 08:44 AM
Quick Reply: Sc and 112 lobe??
