Schematic for TAC Module
was wandering if any one had a schematic of the TAC module for the 03+ DBW trucks.
the reason i am needing one is, caspers electronics is trying to make up an adapter for the use of a C5 or equivalent DBW TB on an 03+ truck. the C5 TB has two separate connectors, one for the TPS and one to drive the TB blade, whereas the TB on the 03+ truck has a single 8 pin connector.
i have the pin-out illustration that Flyer (i believe) posted for the LS2 adapter, which is great, but does not have very much info for the TAC module.
here is the email from justin at caspers, which may help explain the purpose of needing a TAC module or schematic.
ran this by our engineering department. They are about 95% sure it would be ok to do this. However, to verify, they would like to have a TAC module off one of the 2003+ trucks to test on the bench. If there is circuitry internally that separates the two 5V ref lines, running them together could potentially damage the TAC module. Is there a way you could send us a TAC module? Or do you know anyone would could. Let me know.
Regards,
-- Justin
CASPER'S ELECTRONICS, INC.
1333 Wilhelm Rd.
Mundelein, IL 60060
Regards,
-- Justin
1333 Wilhelm Rd.
Mundelein, IL 60060
Originally Posted by Dirty Dave
try this one I have one more but it is to big of an attachment.
mitchellmade
09-27-2015 08:27 PM
supershift67
09-18-2015 08:21 PM
TAPyvehc93
09-14-2015 01:22 PM
