SDPC 5.3 Build
#131
RPM Range will always vary on application, but the cam is not a torque monster, so don't expect to light the tires up without gears and a converter. Mine pulls well past 6000rpm w/ ported heads, but again, every setup will differ. All in all, I think it would be a great camshaft for 4.8 with some gear.
#132
I have a stock converter and 3.42 gears. Can you recommend a cam with good torque? This is a 4700lb reg cab long box 2wd. Stock it made 223hp and 221tq at the wheels. I'm running stock size tires also.
#138
Thanks! It'll make a legit 300rw pull someday.
3.90s will make their way in soon, dropping rwhp dyno #s, but then a Powerbond 25% UD Pulley should even things up. Hoping the gears eliminate some of the dead spot and net a mid 15 in 4000' of air. This pig needs a diet and a converter!
#139
Custm2500's Rude Friend
