SDPC 5.3 Build
Old 12-26-2011, 08:49 AM
  #131
Trucks Sponsor
Beau@SDPC's Avatar
Originally Posted by 03WhiteRCLB
What is the rpm range on this camshaft? How do you think it would do in a 4.8?
RPM Range will always vary on application, but the cam is not a torque monster, so don't expect to light the tires up without gears and a converter. Mine pulls well past 6000rpm w/ ported heads, but again, every setup will differ. All in all, I think it would be a great camshaft for 4.8 with some gear.
Old 01-13-2012, 03:49 PM
  #132
03WhiteRCLB's Avatar
I have a stock converter and 3.42 gears. Can you recommend a cam with good torque? This is a 4700lb reg cab long box 2wd. Stock it made 223hp and 221tq at the wheels. I'm running stock size tires also.
Old 01-13-2012, 04:40 PM
  #133
Trucks Sponsor
Beau@SDPC's Avatar
If you plan to stick w/ stock converter and gear, I would look at doing the Comp 212/218 High Lift (.558/.563) on a 115. It will not have near the dead spot as our 214/218 on a 111.
Old 01-13-2012, 07:29 PM
  #134
Thanks, what should I use for valve springs and pushrods?
Old 01-16-2012, 09:39 AM
  #135
Trucks Sponsor
Beau@SDPC's Avatar
LS6 Springs will work just fine, and I would use Manley push rods. We sell and stock both.
Thanks!
Old 01-16-2012, 09:42 AM
  #136
Trucks Sponsor
Beau@SDPC's Avatar
Quick update. Put the truck back on the rollers Saturday. Only change since the last dyno of 292rw/290tq was E-fans.
Old 01-16-2012, 11:45 AM
  #137
Custm2500's Rude Friend
1FastBrick's Avatar
Nice respectable gain!!! Thanks for the update!!!
Old 01-16-2012, 04:42 PM
  #138
Trucks Sponsor
Beau@SDPC's Avatar
Thanks! It'll make a legit 300rw pull someday.
3.90s will make their way in soon, dropping rwhp dyno #s, but then a Powerbond 25% UD Pulley should even things up. Hoping the gears eliminate some of the dead spot and net a mid 15 in 4000' of air. This pig needs a diet and a converter!
Old 01-16-2012, 07:11 PM
  #139
1FastBrick's Avatar
were do feel the dead spot???
Old 01-17-2012, 09:23 AM
  #140
Trucks Sponsor
Beau@SDPC's Avatar
Under 3k. Of course, it is a full weight CCSB with ported, big valve heads and a 111 LSA camshaft.
Quick Reply: SDPC 5.3 Build
