SDPC 5.3 Build
#141
Since i have a 60e with 125k would a 5.3 build like this be better for the trans than a 6.0 that has lots more tq ? Also can i get this 327 with the new cam and heads already installed? would hate to remove brand new parts and replace......
#143
We would be happy to install the performance parts here in our shop and send it to you that way. You can choose to keep the stock components, or we could offer you a small credit if we keep them.
Unfortunately, the laptop that had the first run file on it crashed and we were not able to retrieve the files.
#144
This is the best I could do. The gains are surprisingly noticeable throughout the entire power band. At 3500 rpm graphs show a 20rw/20ft. lb. difference.
Note, smoothing bewteen the two runs is different. Lower numerical smoothing increases peak numbers, however it varies less than 2rw/tq from 1-5
#148
i have a 06 chevy with a 5.3(2003 motor)! i got it bored 30 over flat top pistons oem. with a 212/218 557/563 lsa115(degreed to 111)! stock heads but put .600 pac racing springs and 7.4 crome molly push rods and a 3 angle valve job!compressions around 9.3-9.5! and boltons r a k&n intake with a 3/4 throt. spacer! pace setter long tubes with x pipe to 2 flow master 40s! built 4l60e 3500 ptc stall with extra bloon plates for nos. posi unit in the rear with 3.73s and i dynoed at furtral motor sports in walker la. an made 324 rwhp an 364 rwtq on 265/35/22s with hp tuner o and i have E fans is that pretty good? or does that seem kinda weak?
#150
PerformanceTrucks.net Forums - FAQ: Board FAQ
