In search of lower IAT's
Old 07-25-2012, 07:19 AM
PWRVTEC's Avatar
I have the stock airbox with ribs smoothed out and inside coated in a boat resin, bottom has a 4" opening with a 4" aluminum tube running down to just above the fender-well lining, and a Arid MIT and my IAT runs about 110 in traffic on a 95 degree day. On the move its about 98-105 it really works well. Don't worry about thinking water will get in as I still have the factory openings so even if the tube is in water the least resistant path will draw the air. Kinda like those AEM CAI bypass valves.
Old 07-25-2012, 09:16 AM
Vortec350ss's Avatar
Andy I'd be interested to see how you routed that tube to the intake. Any help to get cooler air to the filter is worth it IMO. I never removed the plate below my intake either... I really need to take the time to do that.
Old 07-25-2012, 09:34 AM
AndysC3's Avatar
Going up to the air box
How it was routed with the Volant air box.
I cut a 4" hole in the metal plate thats under the intake.
Old 07-25-2012, 09:51 AM
nonnieselman's Avatar
if you relocated the IAT to the EGR port. it will heat soak fast from the engine heat rising and the manifold warming up.
but a quick hit on the throttle and it drops fast.
Old 07-25-2012, 10:48 AM
mvrk10256's Avatar
Hang on. The IAT sensor is a sensor. If you relocate the sensor it wont change the actual intake temperature of the air, you will just be reading the temp from something else.....
Old 07-25-2012, 11:42 AM
ayousef's Avatar
im against that aluminum tube, that thing would get heatsoaked like anything! ask me how I know...
Old 07-25-2012, 12:00 PM
Thats pretty cool... dunno how well it would work with the K&N open air filter set up though.
Old 07-25-2012, 12:05 PM
charcoal03silvy's Avatar
The stock IAT sensor in the MAF is junk...
Old 07-25-2012, 04:24 PM
2007chevy5.3l's Avatar
Pretty much what he said. You can get way better sensors that are more accurate and are alot faster, unlike the stock MAF IAT sensor
Old 07-25-2012, 08:49 PM
Idryfly5's Avatar
ditch the aluminum tube for a plastic one. or heat wrap the tube to prevent some heat soak?
Quick Reply: In search of lower IAT's
