serious fuel problem!!! please advise.
Old 09-12-2008, 06:40 PM
dlt76028's Avatar
Default serious fuel problem!!! please advise.
my truck had a walbro fuel pump and LT headers, i took off the headers and put stock manifolds and cats back on and the truck started popping and dying when i idled for about 4 mins and i would give it gas and it wouldnt do anything but die. so i bought a new stock fuel pump off ebay and drove it and when i got to exactly 3000 rpms it bogged down and wouldnt go unless i stayed below 3000 rpms then it drove fine. so then i put a new fuel preassure regualtor on and it still does it at 3000? i also put 2 new o2 sensors in it last week. so now i have a new problem where it wont go above 3000 rpm ever since i put a new pump in it?? please give me some ideas because im about to push it off a cliff
Old 09-12-2008, 07:00 PM
Truckshop's Avatar
have you put a gauge on it to check pressure?
Old 09-12-2008, 07:05 PM
dlt76028's Avatar
no i dont have a gauge but when we logged it both fuel trims were maxed out and when i floored it the check engine light came on for lean o2s and it went into limp mode.
Old 09-12-2008, 07:09 PM
Truckshop's Avatar
a bad mass air sensor could do that also. need to monitor more data. need more info. stopped up exhaust also. loosen the y-pipe at the manifolds and see if anything changes.
Old 09-12-2008, 07:15 PM
Resident Retard
BlackGMC's Avatar
Here is his log before he changed the fuel pump...
File Type: efi
Old 09-12-2008, 07:27 PM
dlt76028's Avatar
i was wondering about the cats being clogged cuz thats when all this started was when i put them on.... but that couldn't make both banks read maxed out since their past the o2s, could it?
Old 09-12-2008, 07:30 PM
Resident Retard
BlackGMC's Avatar
Have you tried seafoaming it? have you checked the fuel line for damage? I wonder when you threw the driveshaft, if it hit the fuel line and pinched it...
Old 09-12-2008, 09:45 PM
aarolar's Avatar
Check your o2's that's exactly what my conversion did when I started out with bad o2's...
Old 09-12-2008, 10:28 PM
dlt76028's Avatar
their both brand new and the conections are good.
Old 09-13-2008, 10:52 PM
dlt76028's Avatar
no one else has had this fuel cutoff around 3000rpms before?
Quick Reply: serious fuel problem!!! please advise.
