serious problem need help now
#26
whats a boroscope? im sure i can get one somewhere unless its real hard to find. so because it is magnetic what do you think its from?
#27
Tin Foil Hat Wearin' Fool
Originally Posted by trever1t
Chasing the threads while the heads are on will put even more shavings into the cylinder, right?
#29
i had an idea, i was going to say a magnetic retriever, but if the shavings on your spark plug are from *cough* the head, i dont think aluminum is magnetic, this COULD be bad bud. im praying its your spark plug, and the threads are just damaged. Did you try another plug??? whenever i replace the plugs, im extremely careful when threading the, heads arent cheap. and neithe is the repairs on them....
i dont have much else to help on cleaning out shavings, other than i would LIGHTLY coat my finger, with dialetric (spelling) grease, and see if i cant get them to stick to it. im talking about LIGHTLY!!!
someone else my consider that a bad idea, but i dont forsee any problems with it.
jared
jared
