Servo how to?!
I pulled the servo out of the tranny this morning and installed it on my tuck in like 30 min. i thought it was gonna be harder. Im ordering my trans-go tomorrow. I'll keep you guys posted. later
Did you do the 'Vette one or the billet?
Originally Posted by Flyer
Told ya they are easy as hell! It took me longer to get my Y-pipe down than it did to change them out.
See I think that was my mis-step...not dropping the Y-pipe down! Hell I would have paid you gas money each way + $$$ to help me with mine. That still would have been cheaper than the ****** tow I had to do + reinstall.
LOL ... that's my number one rule ... if something's in the way, get it out of the way.
I gotta say too, my Y-pipe is prolly a whole lot easier to remove than yours though. Those headers get it right down close to the bottom. All I need is a 14mm socket, small extension and a ratchet.
I used the Vette servo, and I got the Trans go today, i got it for $115 at my local performance shop. Im gonna start the install tomorrow, I dionthink It will be too bad. I saw the video and I've done much more difficult things. I'll let you know how it goes. The servo worked really well, I felt the difference.
Originally Posted by 01 Thunder
be carefull with hard shifts as the plastic accumulator housing will crack.
if this happens it will bogg just after shifting into second for a second or two then pick up again and take off. the fix for this is to buy a billit accumulator housing. you should be able to get one from trans go, or any aftermarket transmission shop.
I thought I might have had this problem so I dropped the pan and removed the 1-2 accumulator housing. The housing is aluminum and the piston is plastic. I cleaned and inspected both of these parts but found no cracks or defects. Am I looking at the right parts? Is there another 1-2 accumulator somewhere else? Could this be a servo problem?
Here's what happened... right after I installed the Whipplecharger and with factory programming I went for a WOT blast and had a real hard 1-2 shift. It was so firm in fact that it broke the tires loose and the truck started to go sideways. I have to admit that it caught me by surprise. I never expected a neck snapping shift with stock programming. Anyway, that was the only time it had a firm 1-2 shift. Since then I have the exact same symptom that is in the quoted section above. Do you have any ideas on this? I'd appreciate any thoughts you may have.
Thanks,
Gene
