SES light = P0106 & P0135
14 Second Truck Club
Went by autozone and found out it throwing two P0135 codes and a P0106 code. Replaced the MAP sensor and it's still throwing it. Checked all the connections to the MAP sensor and made sure the grounds were tight. Engine smells weird also when running, kinda like it's running rich. What causes it to throw the P0135 codes? Thanks.
PT's Slowest Truck
P0135-O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) ...if the wiring is OK (not broken or shorted), you more than likely have a bad O2 sensor. As for the MAP sensor code, I wonder if the low vacuum characteristics of your cam is creating a problem with pcm logic...I'd assume that with cam numbers like yours, idle vacuum must be pretty low and might be out of range of the parameters set in the PCM. Might need some tuning to compensate.
Thanks for the info! Which side is Bank 1? What code would it throw for the other side? Also, should I save myself the $45 and take the MAP sensor back to autozone and not worry about that part?
PT's Slowest Truck
Since the MAP sensor didn't fix the problem, I'd return it if they'll take it back Also check the harness from the sensor to the PCM for any breaks or corrosion.
legerwn
56
11-15-2015 10:21 PM
carid
10-01-2015 09:22 AM
muncie21
09-07-2015 09:55 PM
