Shift Kit and Pulley Recommendations
Re: Shift Kit and Pulley Recommendations
The TCI kit looks pretty complete. You can view the instructions on their web site. It says that you have to drill out the seperator plate and swap out some acummualator springs. It also says the servo is the same on as on the vette.
So with my combo, just crank pulley or alternator too?
Also, what is the best place to buy these parts from? Would like to support a sponsor if at all possible.
Josh Hucks
Josh Hucks
Josh Hucks
Josh Hucks
11 Second Club
I've got a trans go in my truck w/ a built transmission and it shifts hard all the time. I just learned that you don't need a shift kit w/ a computer controlled transmission. It can be programmed to shift any way you want. Check out Westers web site. I think he's got a program that's specific to the 4l60e. I'd like my truck to shift easy when I'm driving easy and snap my neck when I'm gettin on it.
11 Second Club
Yep, Westers has it and you don't have to take the trans apart. http://westers_garage.eidnet.org/scprice.htm
A TransGo rebuilds the valve body. A clean valve body shift is FAR nicer than a high line pressure shift. I swear by TransGo shift kits and use/install them in every vehicle I own that will take one.
Mine shifts easy when cruising...the will bark 285 ATs out back at WOT
zaathur151
07-06-2015 10:57 PM
