Shift Kit and Pulley Recommendations
Old 09-26-2003, 02:24 PM
whitez71's Avatar
Default Re: Shift Kit and Pulley Recommendations
The TCI kit looks pretty complete. You can view the instructions on their web site. It says that you have to drill out the seperator plate and swap out some acummualator springs. It also says the servo is the same on as on the vette.
Old 09-26-2003, 02:34 PM
Hit Man X's Avatar
Yeah sorry, you are right about it being more indepth than the B&M kit. It looks between a B&M and TransGo. The servo they sell is like $15 from KDS Performance too
Old 09-27-2003, 05:06 PM
Silvette_02's Avatar
So with my combo, just crank pulley or alternator too?
Also, what is the best place to buy these parts from? Would like to support a sponsor if at all possible.
Josh Hucks
Old 09-28-2003, 12:11 PM
Hit Man X's Avatar
Josh Hucks
I'd get the crank and overdrive alt pulley. The OD alt pulley is 1.75"...very tiny and it will spin the alt faster at idle to help undercharge
Old 09-29-2003, 01:10 PM
Alright thanks a lot.
Where should I buy these parts from?
Josh Hucks
Old 09-29-2003, 03:01 PM
Hit Man X's Avatar
Josh Hucks
www.rpmoutlet.com has them
Old 09-29-2003, 04:00 PM
11 Second Club
Grey Silver's Avatar
I've got a trans go in my truck w/ a built transmission and it shifts hard all the time. I just learned that you don't need a shift kit w/ a computer controlled transmission. It can be programmed to shift any way you want. Check out Westers web site. I think he's got a program that's specific to the 4l60e. I'd like my truck to shift easy when I'm driving easy and snap my neck when I'm gettin on it.
Old 09-29-2003, 04:18 PM
11 Second Club
Yep, Westers has it and you don't have to take the trans apart. http://westers_garage.eidnet.org/scprice.htm
Old 09-29-2003, 04:27 PM
Hit Man X's Avatar
They just raise line pressure...
A TransGo rebuilds the valve body. A clean valve body shift is FAR nicer than a high line pressure shift. I swear by TransGo shift kits and use/install them in every vehicle I own that will take one.
Mine shifts easy when cruising...the will bark 285 ATs out back at WOT
Oobray
06-13-2022 03:38 AM
1slwgto
08-16-2015 06:40 PM
OLD BULL
08-01-2015 05:00 PM
Ammadien
07-22-2015 08:50 PM
zaathur151
07-06-2015 10:57 PM
Quick Reply: Shift Kit and Pulley Recommendations
