shorty headers
Old 04-05-2008 | 01:19 PM
99gmcoffroader's Avatar
Default shorty headers
i just boght some used pacesetter shorties, I was just wondering, do I have to go and buy header bolts, or will the bolts from the stock manifold work? I went and bought a new gasket from the dealer, just not sure if I have to go out and buy some header bolts. Wnat to have everything together, as I am planning to install tommorrow afternoon.
Old 04-05-2008 | 06:36 PM
bluedream02's Avatar
you will be able to use the original manifold bolts but some times you may have to use washers depending on the head size of the bolts and also if your original gaskets are copper you dont have to replace them they work better than any other gaskets. you will need to go and buy bolts for the flanges but again the flange will not need a gasket good luck
Old 04-07-2008 | 10:55 AM
AGAMBILL's Avatar
I ran the felpro HP header gaskets and have had no problems. The Heddmans come with new bolts.
Old 04-07-2008 | 10:58 AM
LowBlack99's Avatar
Stock gaskets and bolts will work fine.
flatblack83
03-28-2021 11:28 AM
FlyingLow
11-24-2015 11:05 AM
Superman09
09-25-2015 06:55 AM
Cowboy Tom
11
09-16-2015 10:35 AM
