should 6.0 have trouble getting over 100mph?
Old 10-06-2008, 10:02 PM
  #21
regency's Avatar
i think mine has alot to do with tuning its far from perfect only being a mail order
Old 10-07-2008, 12:21 AM
  #22
GMCtrk's Avatar
Here's a 50 punch. This just looks pathetic. Does this look like normal acceleration for a 6.0? Mods are 93 tune, ported TB and 3" cutout. How can I get this thing to rev faster?
http://www.youtube.com/watch?v=seg3iBgnH-s
Old 10-07-2008, 01:34 AM
  #23
Causey02's Avatar
u need a different tune
Old 10-07-2008, 07:28 AM
  #24
11 Second Truck Club
Cuerva's Avatar
Considering the mods you have, that pull looks about right and looks like it's still pulling. You should be able to go well over 100mph, specially with the tall tires and 3.42's. The needle won't go over 100mph, but when you go over you'll know when you let your foot off the pedal. It'll take a little while before the needle starts moving back down from whatever top speed you reached till you get to 100mph and continue to drop.
Old 10-07-2008, 11:59 AM
  #25
Mark Johnson's Avatar
Been thinking of a Denali/ C3 cluster myself.....................
Old 10-07-2008, 03:17 PM
  #26
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
You need to verify in the tune you are referencing the calibration, and not GMLAN (one of the BCMs). There is actually a flag in the speed limiter section you need to check for this.
You can have the speed limiter turned off in the tune, and the BCM will still step in and shut you down at 100. But, normally if that happens its pretty violent. In the stock tune , it just stops pullling right around 100 MPH and will not go any mph faster.
If your RPM continue to climb once you reach 100, its simply a matter of drag vs hp, and big trucks don't pull really hard at those speeds. But, I would recommend that if you hook up a scanner and not be trying to read your speedometer of tach at high speed. In addition, I think it goes without saying that you need to do so in a safe and controlled environment.
Old 10-07-2008, 03:22 PM
  #27
GMCtrk's Avatar
I am quite sure all speed limiters are removed. I actually did a different run and when I let off the speedo was pegged at 100 so I was indeed over 100. I also never recalibrated for 1.5" taller tires so the speedo is slow. I guess I just expected a 6.0 to pull harder in 3rd. I'm thinking about a yank TT3000 and TR224 cam.
Old 10-07-2008, 03:23 PM
  #28
gtosilverado's Avatar
mine has the 120mph cluster and has no problem going pass 100, all i have is the tune, ud pulley, and not kats. with 3.73 gears.
Old 10-07-2008, 03:24 PM
  #29
Truck Sponsor
Wheatley's Avatar
govornor is not gonna be hit,not possible.LOL
Old 10-07-2008, 05:08 PM
  #30
dlt76028's Avatar
that looks right for a 6.0 with a tune. compare your with my 50 punch and thats what a cam and LTs will do... plus your shifting into 3rd kinda early.
Quick Reply: should 6.0 have trouble getting over 100mph?
