should I be worried about burning valves?
Old 02-23-2008, 10:21 PM
Wearin' da big hat
00ChevyScott's Avatar
Default should I be worried about burning valves?
I just installed my pacesetters and the ORY, but i havent bolted up the 3rd peice of the Y pipe to the stock piping yet. Could I be at risk of burning my valves, or is this sufficient pipe for a short period of time (a week max).
btw, I'm running no cats if that makes a difference
Old 02-23-2008, 11:36 PM
WFOsierra's Avatar
Wouldnt be any different then running open header...
Old 02-24-2008, 12:21 AM
14 Second Truck Club
fastgmc53's Avatar
How do you like the headers? They are next on my list but I think instead of the ory I am going to have custom exhaust built from the headers back. Can you tell a big difference off the line?
Old 02-24-2008, 12:43 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
Not sure on the car/trucks but on the bikes like 5+ inches of pipe is enough to be safe for a while. I believe it is warpage due to the heat difference that is the issue.
Old 02-24-2008, 04:18 AM
Baltimore Whore
Mangled03gmc's Avatar
Not at all, u will be fine. You need alot less pipe then that to burn valves, I mean alot.
John
Old 02-24-2008, 04:29 AM
jkwalkercchs's Avatar
no dude you are ok u would have to have demolition headers to worry about valve damage
Old 02-24-2008, 08:30 AM
Wearin' da big hat
K good, cause it sounds like a f*cking beast how it is right now. I still need to connect it to the rest of my exhaust system.
For lenth reference, the end of the pipe right now ends up right at the back of my front door.
Old 02-24-2008, 09:57 AM
Hydramatic's Avatar
Drive around for four hours, stop 'n go, with your exhaust like that and you'll be begging for stock exhaust again! I opened up my exhaust with STOCK headers and cats still on at the Y flange, and did exactly this. Fun for a couple hours, but my *** started going numb....I don't know how those Le Mans 24 hours guys do it...
Old 02-24-2008, 10:01 AM
Wearin' da big hat
its been 3 days full of driving and I'm still not tired of it
Wolftrk99
12-03-2015 08:12 PM
00loudchevy
12-03-2015 05:54 PM
Avalanche2002
11-30-2015 07:31 AM
JordanH
10-03-2015 03:59 PM
Velocity1
10-02-2015 08:01 AM
Quick Reply: should I be worried about burning valves?
