Shrader Valve Help!
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
1 Post
Originally Posted by BigKID
What is that gonna do??
If you want to keep from spewing gas from the rail when you pull out the schrader valve, pull the fuel pump relay then crank the truck and let it die. Taking the gas cap off is not going to relieve the pressure in the fuel rails.
btw.. a female 4AN is what you need to connect your hobbs switch to the fuel rail at the test port.
