Shrader Valve help!!!!!!!!
Ok Im getting my fuel for the n20 system from the shrader valve. Im wanting to take my noids off and get them looked at and/or serviced. I need to know the best way to be able to stop fuel from leaking when I remove the fuel noid. Can I just cap where the shrader was or do I have to buy a whole new shrader valve. If it makes a difference coming off the shrader I have a single hole purge/gauge adapter and hooked to it is a FPSS and then obviously a hose and then the fuel noid. Thanks for the help!
Originally Posted by Deckhand
ive read that some ppl have capped it with just that little cover it worked. If I couldnt find the actual little valve to stab back in there, I would try to get ahold of a metal screw cap (like the billet ones for wheels, or somthing like that)
