Silverado SS has a clutch fan?
Old 12-30-2003, 05:25 PM
Adkoonerstrator
XLR8NSS's Avatar
The VSC with either flexalite 282's or 295's is the closet you'll come to plug and play with A/C control, manual control, and thermostatic control all in one package.
Old 12-31-2003, 03:20 PM
LOW2000's Avatar
Well there are power sources all over the truck with connectors, and the ECM reads engine temp so there should be a way to make it work. I'm just in lazy mode right now, thats why I want a setup like this, also, it'd be cleaner than the wires strung all over the place and miswired relays or fans that dont shut off that are always posted about.
Thx for the help though guys.
Old 01-01-2004, 11:24 PM
Wasn't Parish8 working on getting his PCM to control the fans? You would still have to run power to it.
Old 01-02-2004, 12:29 AM
Hit Man X's Avatar
BenKey... All you gotta do is set the truck PCM to turn on the fans at your desired temp and add a pin to the harness. www.ls1truck.com has more info on it...
Old 01-02-2004, 12:50 AM
Adkoonerstrator
XLR8NSS's Avatar
That is true. If you want all the other features of the VSC you still have to wire up relays and stuff though. The VSC has all that in one little compact package.
Old 01-02-2004, 06:26 AM
Still moddin'
Reckless's Avatar
How much $$ for this setup?
Old 01-02-2004, 07:07 AM
$390 or so. Got mine through Tbyrne.
Old 01-02-2004, 09:29 AM
Adkoonerstrator
XLR8NSS's Avatar
Yep, what BenKey said. The 282's are for the 34" wide radiator core in the 6.0L trucks and some SUV's. The 295's are for the 28" wide radiator cores in everything else.
Old 01-02-2004, 09:56 AM
14 Second Truck Club
onyx's Avatar
sounds like to much of a headache for the electronically impaired, such as myself...
thing is... its hot as hell in the summer in Tucson, so its best for me to have a clutch fan and have it running all the time..
Ketis
07-23-2015 12:37 PM
ferrellrooster
07-13-2015 09:53 AM
rojeho
07-12-2015 06:10 PM
Quick Reply: Silverado SS has a clutch fan?
