Silverado SS with heads and cam
Old 03-13-2004, 02:04 PM
PCMFORLESS's Avatar
I'm at almost 10.5 to 1 now.
Old 03-13-2004, 03:01 PM
Im at 10.3:1 and with just the increased compression and porting i got some big gains. It really loves the 100oct. with some methanol/alcohol mix. Did you dyno with race gas or just pump gas? With compression that high you would see some good gains with 100oct.
Old 03-13-2004, 04:51 PM
PCMFORLESS's Avatar
I'm using pump gas, but will try the 100 at the track.
thanks,
bryan
Old 03-13-2004, 04:58 PM
All this sure makes me wonder what my truck would dyno at. Thanks for all the info, Bryan.
Old 03-13-2004, 09:08 PM
You're not the only one wondering, Ben. Your mods list should produce quite impressive numbers...
Old 03-13-2004, 09:28 PM
BigTex's Avatar
I'm wondering too. I may find out this week.
Ben better put down some impressive numbers. He's on the brink of buying a nitrous kit to top it off, and low dyno numbers may just push him over the edge.
Old 03-13-2004, 10:47 PM
Cuz I AM a BADMOFO
BADMOFO's Avatar
Originally Posted by PCMFORLESS
It is surprisingly small. It is a custom grind with durations in the 21x range and lift in the .54x to .55x range. I don't have the card in front of me, but also am not supposed to give out the numbers either, but you can see the ballpark that it is in.
Later,
Bryan
Old 03-13-2004, 10:48 PM
BigTex - shhhhh.
Old 03-13-2004, 11:26 PM
BigTex's Avatar
Originally Posted by BADMOFO
Bryan is in with JD's performance. He is running JPR heads. It sounds like they are working options for supplying truck cam and head packages. I don't blame them for wanting to keep a little secrecy in this setup.
Old 03-14-2004, 02:16 AM
PCMFORLESS's Avatar
I'd definitely like to see what Ben's truck is up to on the dyno as well. I honestly haven't had any issues with my truck or the 02 Escalade we did with the AWD and they are both making pretty good power. The only thing I think I need to do now is beef up my trans along with the new converter. When the tranny is cold it will slip from first to second.
Later,
Bryan
Quick Reply: Silverado SS with heads and cam
