Silverado SS with heads and cam
Im at 10.3:1 and with just the increased compression and porting i got some big gains. It really loves the 100oct. with some methanol/alcohol mix. Did you dyno with race gas or just pump gas? With compression that high you would see some good gains with 100oct.
Originally Posted by BenKey
All this sure makes me wonder what my truck would dyno at.
You're not the only one wondering, Ben. Your mods list should produce quite impressive numbers...
Cuz I AM a BADMOFO
Originally Posted by PCMFORLESS
It is surprisingly small. It is a custom grind with durations in the 21x range and lift in the .54x to .55x range. I don't have the card in front of me, but also am not supposed to give out the numbers either, but you can see the ballpark that it is in.
Later,
Bryan
Later,
Bryan
I'd definitely like to see what Ben's truck is up to on the dyno as well. I honestly haven't had any issues with my truck or the 02 Escalade we did with the AWD and they are both making pretty good power. The only thing I think I need to do now is beef up my trans along with the new converter. When the tranny is cold it will slip from first to second.
Later,
Bryan
Later,
Bryan
