Single Cam Swap= 95 HP Gain!
Old 10-15-2005, 09:21 PM
  #41
treyZ28's Avatar
Originally Posted by Black02Z71
I don't understand why gm puts so little timing in these things from the factory, emissions maybe? I was just comparing my current advance table vs the factory 5.3L table, factory only has 13-16 degrees vs my current 27-29 at wot. I then looked at what the predator programer was running for timming and it's only 18-21. So you can see how you can pick up 30hp+ with tuning.
95 hp may sound like a lot, but this is at the engine, at the wheels it would only be like a 75 ish hp gain, which is still a pretty big gain.
definately emissions. it wasn't for emissions we would all have more power, more reliability, cheaper cars, better gas milage and lung cancer
Old 10-15-2005, 09:45 PM
  #42
mattrem's Avatar
Then you need all of the pipes from the manifold back,there is no y pipe in a SS . Its dual to the muffler, then 3 inch out of that.
Old 10-15-2005, 10:11 PM
  #43
treyZ28's Avatar
ehh **** it. I'll just get custom fabbed true duals. Sounds like its going to be expensive. I just wanted a stock-esk setup.
Old 10-15-2005, 10:20 PM
  #44
Jethro_3's Avatar
Check the link to look at pics of the pipes on mine which are the same as an SS. Dual in to the exhaust and dual out with a "Y" about 6" beyond the muffler with a 3" over the axle and out....
Ammadien
07-22-2015 08:50 PM
FlowmasterMufflers
07-22-2015 12:47 PM
4B11T
07-13-2015 03:48 PM
Aboss
07-09-2015 10:28 AM
mrgrim
07-08-2015 08:12 AM
Quick Reply: Single Cam Swap= 95 HP Gain!
