Single Turbo
Keep answering them XLR8, your doing great.
The stock coolant tank was plastic and to close to the heat for comfort.
The power depends on boost, even at 5 psi it will keep 500 ftlbs + starting at 2500 rpm.
With the boost up we have seen 900 ft lbs at 4000 rpm. The kit we will sell has a safe setting around 8 psi at 5500 that produced 680 ft lbs and about 640 hp at the flywheel.
Kurt
Kurt
Impressive ... I still can't get over how clean that was. Even the shroud on top look like it was remolded with the edges curved where it was cut. That is a really nice install. Very impressive power gains too. Is this on a stock 6.0 or what.
Stock internals and compression ratio in that SS?
Just how do you come up with 680 ft lbs and 640 hp at the flywheel?
****EDIT****
I just read a post you made about an engine dyno.
****EDIT****
O HELL yea this is what i like seeing just need a tranny then well whoever is going to come out with the first turbo kit. i am going to have to refrain my self from looking on here for a while cause i am getting excited.
Adkoonerstrator
Kurt "427" is making them but, is not a sponsor here so you'd have to PM or email him about it. Sorry Kurt
PS - There is no kit available at this time but, may be in the near future.
