Smaller Water Pump PUlley?
Old 05-01-2008 | 10:54 AM
Originally Posted by rclnc
Two idlers.. if you are doing an 8 rib.
You can have ASP make them or you can use Metcos. ( I don't know what ASP's look like - but I know they can make billet aluminum or steel - for about the same price)
ASP looked at the two 100 mm Metcos I had and said they are wide enough to support an 8 rib. You are going to need a bushing for the Metco to sit on also. You can get this with David at Magnuson. You are also going to need a slightly longer bolt, you can get it from a local hardware store.
Don't go buying and sending anything without first calling him. ASPracing. Talk to Lee Cooper.
i called him as soon as you posted this morning, lol. it's all good. yeah, i'm dumb. i meant to say 2 idlers. Exactly which Metco idlers do i need? Reichard Racing said he sells them for $89 each. Not sure if they are the same or not
Old 05-01-2008 | 11:12 AM
rclnc's Avatar
I'm sure Reichard sells Reichard. and I could not tell you how wide his are. . I bought my Metcos off of ebay from Atomic performance. He's selling one right now for 64.50 - he shows to have 2 in stock. Just the pulley for the late model 03 04 cars or trucks. You don't need any of the other kind with brackets and such.
Old 05-01-2008 | 11:15 AM
rclnc's Avatar
How much is ASP going to charge you for the waterpump pulley. You going with steel or aluminum. You can also get him to measure you up for the new belt.
ullose272
08-05-2016 02:05 PM
slowswb
09-05-2015 02:27 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
mr03silverado
09-02-2015 11:43 PM
Tigger Welder
09-02-2015 08:17 AM
Quick Reply: Smaller Water Pump PUlley?
