smallish cam were
smallish cam were
I been lookin around for a cam in the mid to upper 21x for duration and something between .550-.600 lift on a 112 or 110 lsa does anyone know if theres a off the shelf grind that fits this or not. if not I guess I'll just stick with my 210/218 .551/.551 112lsa.
Don't you like your cam you have now. I thought it made good power all over thats the reason I was lookin to go alittle bigger? cause I basicly plan to copy your setup exactly except go with some cnc 243s and maybe alittle higher cr, depending on what I need as far as gasket to get my quench right. get yours on the dyno so I can see what its makin down low.
