Snow Performance kit installed
Very nice kit, install was very simple. For now I am using straight denatured alcohol, although unless I can find some cheaper stuff, I'll be switching to methanol for ~$3/gal - I made a few part throttle runs, and one WOT, and it almost sucked down half a tank (see pics). Part throttle seemed to bog down a bit, but WOT felt very nice. Results of dyno tuning will be posted in the next few weeks. I'm going to get alot of before/after numbers - as-is, with injection, with increased timing, and most likely more boost (2.9 pulley).
Nothing like ice-cold boost
Originally Posted by greentahoe
where did you put the controller?
kevin - yes I'm planning on the 20th if I can get on the dyno before then.
Originally Posted by j's01silverado
You going to sell me the 3.0 pulley back? Im going to get a meth kit and want to pulley up a bit.
I just called around and found a shop with methanol - $2.75/gal , so I'll be switching to meth or maybe a mix with water.
