Snow Performance kit installed
Old 10-31-2005, 02:59 PM
Gran Patron's Avatar
Nice.........really nice!! You aint kiddin' about ice-cold boost!!!
Old 10-31-2005, 03:42 PM
12 Second Club
O3GMC's Avatar
Originally Posted by fogle04
2.75 here I come
Old 10-31-2005, 10:27 PM
greentahoe's Avatar
Originally Posted by O3GMC
If you look close, its just to the right of the tank.
kevin - yes I'm planning on the 20th if I can get on the dyno before then.
Is that a black controller with the Snow Logo?? I hope not. mine is a gay blue with no logos or anything
Old 10-31-2005, 11:17 PM
12 Second Club
O3GMC's Avatar
Yeah I guess they redesigned it - I mounted it upside down to have the controls accessible and the boost tube pointed in the right direction.
Old 11-01-2005, 12:29 AM
Bad_Apple's Avatar
I almost went with the Snow Performance Kit, but i got the Progressive Alky Control Kit. I plan on installing mine this week, and since I can get Meth for free thats what I'm going to use. How much H.P. can these kits help a truck untuned and tuned.
Old 11-01-2005, 02:08 PM
bud8fan's Avatar
Possibly, I'll see how things go on the dyno first. But with heat not being an issue, I see no reason not to use the smallest pulley I can (is 2.9 the smallest we can go or 2.8?)
I just called around and found a shop with methanol - $2.75/gal , so I'll be switching to meth or maybe a mix with water.
what are your iat's before and after and what boost psi do you have it coming on at...
Old 11-01-2005, 02:53 PM
TXsilverado's Avatar
badass cant wait to see it on the 20th
Old 11-01-2005, 03:26 PM
12 Second Club
O3GMC's Avatar
Haven't checked IAT's yet but so far I've only used denatured alcohol, and supposedly a 50/50 mix of water/meth is much cooler. I had it come on at 4 or 5 psi but that seems too soon, causes it to bog down a bit, I think 6 might work better.
Old 11-01-2005, 07:46 PM
12 Second Club
O3GMC's Avatar
Went out and did a few WOT runs, highest IAT I saw was 123, but its also in the high 50's here and I'm sure the intercooler is getting nice and cold as well.
I set the turn-on psi to about 7, and reduced the pump speed a little, and also fixed a pretty big leak I was unaware of on the pump outlet fitting - first rolling part-throttle blip to 7psi got the tires loose immediately....and 80-100 went by FAST at wot I'm very impressed with just the cooling benefit so far, and I'm not even using meth/water yet which is supposed to be colder. When I got home the blower inlet was ice cold
Dyno tune with more boost and timing next week
Old 11-01-2005, 07:57 PM
v8
17,16,15,14,13,12,11 Drvr
well jacob your on your way to 11's, good luck and see you on the 20th.
Quick Reply: Snow Performance kit installed
