So I had Pat G spec me a new cam
He spec'd the cam for a Procharger D1-SC running 12 lbs of boost.
Tin Foil Hat Wearin' Fool
Whys that? The cam I have now is bigger and low end torque is almost non existent lol.
what takes 4 times longer? To receive the cam? Thats not that big of an issue. Not in too much of a hurry. The racing scene here is pretty much done until next winter. It to freakin hot here.
Pat G has a deal worked out with EPS, I'm sure he gets a cut of each cam. Comp has some new lobes out that are really good and you can get them to grind your cam to the specs he gave you. No reason to wait on Geoff to screw around for a month or two before he finally orders your cam. I'd order through Texas speed, they've always delivered very quickly and taken care of me.
Wide splits with wide LSAs have crappy midrange tq but pull well up top. Your deep gears, short tire, and high converter will mask most of that. The only time you may notice it is locked up going down the highway.
You can get it cheaper through a vendor. I didn't want to wait for that or take the chance that the order would get screwed up.
FormerVendor
I called Comp directly to order my custom ground cam just back in December of last year. From the day I placed the order with them to the time it arrived at my door was literally 4 days! No BS! I was very impressed and pleased.
