So I had Pat G spec me a new cam
#22
Tin Foil Hat Wearin' Fool
That cam will perform well with your combo it'll just be shifting higher than 6400. Any reason why you're set of 6400?
#24
Andy FWIW I shift my cam at 6350 at the track and its a 222/226 that I had spec'd to run NA boost in mind. Granted I don't know how a procharger changes things as far as shift points compared to NA, but I probably wouldnt go much larger than a 222/230 or so. The other thing is those WCCH heads LOVE lift in the .580 range. Their .600 lift flow is actually less. Again I dont know how that changes with boost, but its something to note.
#25
if youre gonna run 11-12psi you will make boost maybe even below 3000rpms.
I ran a vortech on my Z06, and with only 5psi at 7000rpms, I already made positive manifold pressure at 3500rpms.
