So my LPP Y-pipe showed up today, WOW (pics)
Baltimore Whore
Thanks Jim, you will have them in a day once they are shipped..You will be happy with the headers.. They look good. Only thing I am not a huge fan of is the SW tags they welded onto the front primaries. I think ima cut them off
my four in exhaust is alomost perfectly straight. I didnt order a d max exhaust or BS. I just took a slight bend into the joint were the pie hits the muffler and its about perfect. dumped of course...
Baltimore Whore
I tell you what if there headers look as good as this Y pipe, they are the best deal out there(if they fit) I am still kinda impressed..
Also the slip fit, was actually kinda tight, took a little bit of a push to get them together..
CHARCOLD-
Do you have any pics od your exhaust, so I can get a idea..Also are you stainless??
Thanks gents
CHARCOLD-
Thanks gents
Im running a 4nch i think its alumunized steel?, or galvanized peice of four inch back to a 4 inch deisel flo thru muffler. I will try to grab pics.
just for some sort of a reference, this is three inch pipe, with a bend. We just ran 4 inch straight through that same hole with no bend. muffler stayed in the same place. back when I had a 60e.
If you see that first clamp, right by the wategate, there back is 4 inch. used a reducer to get on to it. All v bands. two total and exhaust removes pretty easily. I have a muffler with about a foot. ANd just a straight joint of 5 foot pipe.
