so why to they say it is too big...
hi, i have a 214/220 cam in my truck right now, i have sitting in my room a tr224. i have a 5.3 in an extended cab, i want to put the tr224 in my 5.3 and everyone is like well thats a big cam for a 5.3, wats the problem with a cam of that size, i see a bunch of ppl running them in 5.3s i was just wondering wat the problem was, and i was told to use a 3600 stall with this cam but i read on here that some are running 3000-3200. so i dont kno, any help will be appreciated. thanks
PT's Slowest Truck
224 is a lot of duration for 323 cubes in a daily driven 5200 lb truck, you'll have to spin it quite a bit to get to the meat of the powerband of that cam in a 5.3, and I'd suggest at least a 3400 converter to get you into that powerband sooner, or it may be soggy down low. But if you're dead set on it, slap it in and find out for yourself...opinions vary
Baltimore Whore
For a 5.3, it is not huge, on the bigger side, kinda. But in your case you have a heavy truck, would def want that bigger verter to take full advantage of that cam.. In a lighter truck it would be better, due to the effective power range of that cam, weight factor.. Like said the cam you have now will prob be just as good, but the tr224 will be more of a hit when the power comes on(peaker hp) and pull a lil more in the rpm band
talked to futral and a couple of ppl that have put cams in ls motors, i want to run a 3600 but was just checking my options, i am puttin 3.73s cause i will be running highway alot so i dont want to kill my gas mileage, i just wanted to kno wat the big deal was with it. i havent even stalled this cam yet so i was trying to decide to just stall and keep this cam or start over with the tr224 and stall it. thanks
