so why to they say it is too big...
#72
got me a pair of 706 heads that im going to get milled, im not sure how much though, its between .30 and .50, the .30 seams to be common, ill call em up and see wat they say, hopefully i can bring em this week
#74
i got away with going .45 on my 706 casting....good luck to you...
#76
how much difference does it make milling heads? i know it ups the compression ratio but what im wondering is if i milled the heads on my 5.3 like .30 how much would that up my compression? like 10.5 to 1? and what kinda power increase would you see out of it? sorry i have been wanting to ask for a while
#77
.30 makes it a 10.1, im waiting for a call back to see wat they say, i have read that some ppl see 20 hp and around 20 lb tq but idk
to darkblue5.3- y did u get away from .45?
#78
i was just wondering if i got the heads ported and polished then had them milled to up the compression what kinda power gains i would see... i was figuring maybe 30 hp.... but if i did the heads 90mm intake and u/d pulleys i shoudl see a good power increase i would think
#79
i called the shop about my heads today and he recommends only doing .30, he says that is the most he would go just in case, thunder racing uses these ppl so i figure id go check em out, he said $125 and they will be done the day after i drop em off so yea
