so why to they say it is too big...
Old 01-24-2010, 01:59 PM
  #71
Mr.Nobody's Avatar
how do u like the cam?
Old 01-24-2010, 10:50 PM
  #72
Mr.Nobody's Avatar
got me a pair of 706 heads that im going to get milled, im not sure how much though, its between .30 and .50, the .30 seams to be common, ill call em up and see wat they say, hopefully i can bring em this week
Old 01-25-2010, 11:07 AM
  #73
Bumpers's Avatar
it does pretty good... its not a drag truck or anything but its def a good bit faster than stock and sound good too... i would suggest atleast a 3200 converter with it
Old 01-25-2010, 11:22 AM
  #74
Darkblue5.3's Avatar
i got away with going .45 on my 706 casting....good luck to you...
Old 01-25-2010, 11:26 AM
  #75
224 is not a big cam, if u thought people telling you its a big cam, i can only imagine what they would have told me when i put my 228/228 on my 5.3.
  #76
Bumpers's Avatar
how much difference does it make milling heads? i know it ups the compression ratio but what im wondering is if i milled the heads on my 5.3 like .30 how much would that up my compression? like 10.5 to 1? and what kinda power increase would you see out of it? sorry i have been wanting to ask for a while
Old 01-25-2010, 01:40 PM
  #77
Mr.Nobody's Avatar
.30 makes it a 10.1, im waiting for a call back to see wat they say, i have read that some ppl see 20 hp and around 20 lb tq but idk
to darkblue5.3- y did u get away from .45?
Old 01-25-2010, 03:52 PM
  #78
Bumpers's Avatar
i was just wondering if i got the heads ported and polished then had them milled to up the compression what kinda power gains i would see... i was figuring maybe 30 hp.... but if i did the heads 90mm intake and u/d pulleys i shoudl see a good power increase i would think
Old 01-25-2010, 08:14 PM
  #79
Mr.Nobody's Avatar
i called the shop about my heads today and he recommends only doing .30, he says that is the most he would go just in case, thunder racing uses these ppl so i figure id go check em out, he said $125 and they will be done the day after i drop em off so yea
Old 01-26-2010, 08:32 AM
  #80
The_Rizzle's Avatar
When you intall the decked heads you could always use the thinner head gaskets, should bump your comp up another 1/4 point.
Quick Reply: so why to they say it is too big...
